Revit MEP
Active Contributor
jainn
Message 1 of 4 (361 Views)
How to connect Hangers
361 Views, 3 Replies
10-04-2011 07:11 AM
Hi All,
in my application i have to connect a single pipe to hangers in autodesk MEP 2012
Pls suggest.
Thanks in advance
Active Contributor
Message 2 of 4 (206 Views)
Re: How to connect Hangers
12-03-2012 09:58 PM in reply to: jainn
I know there is a tool which could help you on this. Check detail please go to: SupportAndHanger
Revit Applications provider[revitapp.com].
Valued Contributor
Sandleaz
Message 3 of 4 (197 Views)
12-04-2012 06:17 AM in reply to: revitapp
With pipe hangers (and to a lesser extent duct hangers), you want to make sure you're using the correct type.  I'd suggest go to a manufacturer like cooper b-line or anvil, find your hanger(s) that you want to use, and model them --- or you can create them without the manufacturer's dimensions if you just want the rough size and shape of the hanger.  Not sure how in depth the application is in terms of adding upper attachments (which you can create as separate families) or accessories like insulation shields or how it handles stacked pipes.
Active Contributor
Message 4 of 4 (189 Views)
12-04-2012 06:40 AM in reply to: Sandleaz
Thanks Sandleaz for your suggestion. We will try to provide inbox hanger as from the manufactory in next version. However, current user could also create their own hanger and use it in current version. And the key value of this tool is to help use auto layout the hanger and manage the connection with the pipe/duct/cable tray or conduit.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
