Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
How to change the size of a heat pump to export to AutoCAD MEP
3 REPLIES 3
DHAC
519 Views, 3 Replies
I am new to Revit and i am trying to change the size of a climateMaster heat pump to a larger size for my drawing. Revit files come in one size and need to be modified to get the larger cabinet size. How is this accomplished?
Any help would be appreciated.
3 REPLIES 3
danielkazado
in reply to: DHAC
Is it possible to share the family so we can check the parameters.
Daniel Kazado
Please use Accept as Solution if your question is answered.
You may Give Kudos if the answer is helpful.
DHAC
in reply to: danielkazado
Daniel,
Sorry for the delay. Attached is the Revit file I am trying to modify.
danielkazado
in reply to: DHAC
First you place the heat pump to your view.
Select the heatpump and click Edit Type button in Properties tab. If you can not see the properties tab right click and select properties.
In the window opened, click Duplicate on upper right, give a name to the dublicated family.
Then change the dimensions as you require like Water Outlet Radius etc. You may see the dimensions down under Dimensions group.
You will have a new heatpump. You can duplicate the family as much different dimension as you need.
Hope this helps.
Daniel Kazado
