I used the right click and selected "Hide Elements > In View" and now I cannot restore the elements that I hid. The unhide button does not reveal these hidden elements. At this point I am not sure where to go. There is no right-click item on the menu that will reveal the selected elements from previous selection. I could really use some help on this one as I am about finished with this model and I am not sure if the colision test will check for these hidden elements.
Any suggestions would be helpful, because I have run out of ideas to check for.
TB
You have to be zoomed in to the element in the view that the element is hidden in when you select the "Reveal Hidden Elements"; select the element or item that you want revealed, then "Toggle Elements ..." and you are back in business.
