Is there a way to hide some elements that have been linked from the architectural drawings? When I pick the architectural drawing it is a single element and I am unable to hide specific elements.
Specifically; I linked the architectural drawing. In the section or elevations I do not want to see level tags (example the finish floor, top plate ext.)
Go into Visibility Graphics, to the Revit link tab, under display settings, (you probably have this set to by host view, change to custom. Now click the custom button & under model categories change that to custom, then you can go in & shut off what you would like. Good Luck.
