Revit MEP Forum
Hide elements from the architectural drawings
1 REPLY 1
sescadd
378 Views, 1 Reply
Is there a way to hide some elements that have been linked from the architectural drawings?  When I pick the architectural drawing it is a single element and I am unable to hide specific elements.
Specifically;  I linked the architectural drawing.  In the section or elevations I do not want to see level tags (example the finish floor, top plate ext.)
1 REPLY 1
in reply to: sescadd
Go into Visibility Graphics, to the Revit link tab, under display settings, (you probably have this set to by host view, change to custom. Now click the custom button & under model categories change that to custom, then you can go in & shut off what you would like. Good Luck.
