Revit MEP Forum
Help with Lookup Table
5 REPLIES 5
norcaljess
3119 Views, 5 Replies
I'm trying to create a new parameter and add it to my Lookup Table.  Here is what I'm trying to do, every time I try this, it says "Invalid Input".  What am I missing?
(Adding a Thread Depth parameter to my Elbow - Threaded - MI - Class 150.rfa family.)
  • Open Lookup Table, save as new name.
  • Revise the Lookup Table Name in my Family Types to match the new name.
  • Add new column to new lookup table.  New column header is "ThD##length##millimeters".  Filled in the thread depth for each size of pipe fitting, or in other words, for each nominal diameter size.
  •  Add new parameter to family
          New Family Parameter, named Thread Depth, Instance Parameter, Discipline is Piping, Type of Parameter is Pipe SIze.  Grouped under Dimensions.
  • Add Formula.  This is the part I am unsure of.
text_file_lookup(Lookup Table Name, "ThD", 0.1 * Nominal Diameter + 1/64", Nominal Diameter)
I think this should work, but it's not.  What am I doing wrong with this formula?
Jess
5 REPLIES 5
norcaljess
in reply to: norcaljess
Never mind.  I got it.
If anyone wants to know....
There was nothing wrong with my Formula.  It was directly tied to WHEN and HOW I saved the replacement lookup file.  Even if I thought I was saving over an existing file, for some reason, Revit wasn't seeing that.  So it wasn't updating.  Once I got all of the information that I needed into my lookup file, I saved it as a completely new name, then added the new Lookup File Name to my Family Types, and lastly, added the formula.  Then it worked!
Jess
James.Klatt
I am going crazy getting this to work.   I am trying lookup tables and I keep getting invalid input.  I have gone down to a simple test...
The csv at the top "Motor.csv"    only has 2 columns... first column which is the driver and 2nd column to be filled in.  Attached is a screenshot of the family.  I just want this to be number values but that wasn't working so I tried changing it to lengths and still nothing.
Tried doing a save as with a different name and still no go.  Tried closing and re-opening revit after changes and still no.
Help anyone?
lazar1978
in reply to: James.Klatt
Hi James!
I got almost the same problem. Try to use Notepad, not Excel...Probably helps?
AL-ZAATRA
in reply to: lazar1978
HI EVERY ONE , CAN ANYONE HELP ME WITH LOOKUP TABLE IN PANEL SCHEDUAL, I TRIED TO LEARN ABOUTLOOK UP TABLE AND USING IT IN MY PANEL SECHDUAL
Secttor
in reply to: AL-ZAATRA
@AL-ZAATRA - describe your problem.
Revit MEP - Electrical Certified Professional
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
Rail Community
