I'm trying to create a new parameter and add it to my Lookup Table. Here is what I'm trying to do, every time I try this, it says "Invalid Input". What am I missing?
(Adding a Thread Depth parameter to my Elbow - Threaded - MI - Class 150.rfa family.)
text_file_lookup(Lookup Table Name, "ThD", 0.1 * Nominal Diameter + 1/64", Nominal Diameter)
I think this should work, but it's not. What am I doing wrong with this formula?
Jess
Never mind. I got it.
If anyone wants to know....
There was nothing wrong with my Formula. It was directly tied to WHEN and HOW I saved the replacement lookup file. Even if I thought I was saving over an existing file, for some reason, Revit wasn't seeing that. So it wasn't updating. Once I got all of the information that I needed into my lookup file, I saved it as a completely new name, then added the new Lookup File Name to my Family Types, and lastly, added the formula. Then it worked!
Jess
I am going crazy getting this to work. I am trying lookup tables and I keep getting invalid input. I have gone down to a simple test...
The csv at the top "Motor.csv" only has 2 columns... first column which is the driver and 2nd column to be filled in. Attached is a screenshot of the family. I just want this to be number values but that wasn't working so I tried changing it to lengths and still nothing.
Tried doing a save as with a different name and still no go. Tried closing and re-opening revit after changes and still no.
Help anyone?
HI EVERY ONE , CAN ANYONE HELP ME WITH LOOKUP TABLE IN PANEL SCHEDUAL, I TRIED TO LEARN ABOUTLOOK UP TABLE AND USING IT IN MY PANEL SECHDUAL
@AL-ZAATRA - describe your problem.
