Revit MEP Forum
Halftone existing pipe fittings
4 REPLIES 4
2374 Views, 4 Replies
Revit MEP 2012
I am working on a remodel job that has existing piping. I halftoned the existing piping and fittings. The piping halftones but the fittings do not. The halftone is done in the Phasing dialog box. Any one have an idea how to halftone the fittings?
AJ
4 REPLIES 4
oh yea see the attached.
Some one in the office figured it out for me. The bottom primary range and the view depth level has to have the same offset.
SNBurford
This worked, thanks
Setah B.
Yes, it fixes the fitting issues. However the beyond line style doesn't work and the below ground/slab piping doesn't show dashed if the view depths are set the same.
