i am doing one project in that i want show two circuits from one light. one from normal DB, another from emergency DB. I was connected normal DB. But another DB was not recognised. i am given two connector for emergency light. which parameters will change for complet this task.
please help to complet this task.
siva
If you are looking to report the electrical data of the secondary Electrical Connector, you will have to draw at least a small piece of Wire from that Connector and then create a Wire Tag to report the Circuit Number, Panel, etc. in lieu of directly tagging the Lighting Fixture.
