Revit MEP
Distinguished Contributor
Happyunited123
Message 1 of 3 (290 Views)
Gate Valve
290 Views, 2 Replies
03-06-2012 01:18 AM
I am trying to insert a gate valve in to my project. I have loaded in the default Revit one and the size only goes to 150mm DIA! I need one that is 500 dia and maybe bigger. I thought the default one would be able to adjust to the pipe size like bends/tees can do. I don't want to have to draw a few different sizes of valves so id there any way I can amend the defualt one or change the look up table to make it bigger?
Also any good sites for downloading material?
Valued Mentor
julianjameson8403
Message 2 of 3 (289 Views)
Re: Gate Valve
03-06-2012 02:07 AM in reply to: Happyunited123
Probably best way would be to create a type catalogue which incorporates the existing values and additional ones, unless you want to use manufacturer specific sizes/dims. If memory serves correctly, pipe accessories aren't related to lookup tables so that option won't work.
This site may be of use
http://www.smartbim.com/SmartBIMObjectFinder/ObjectFinder.aspx#area=2
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
*Expert Elite*
abulla
Message 3 of 3 (277 Views)
Re: Gate Valve
03-06-2012 06:32 AM in reply to: Happyunited123
Nibco and Zurn also have some nice gate valve families on Autodesk Seek.
http://seek.autodesk.com/search/gate+valve?source=SearchBox
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
