Revit MEP Forum
Flexible duct view
6 REPLIES 6
chunky2k
6837 Views, 6 Replies
Flexible duct view
Dear all
am attaching a picture with this question
on the left i connected a diffuser to a duct with flexible
on the left is my drawing, as you can see the connection is like lines | | | | | |
on the right side is another drawing, as you can see it is showing full flexible detail
can this be done ? and how ?
regards
Variable Integrated Package L.L.C
Abu Dhabi - United Arab Emirates
6 REPLIES 6
abulla
in reply to: chunky2k
There's an option in your flex duct properties to change the line style, pick the "Flex" style (once you pick Flex it will remember your selection and default to that).
chunky2k
in reply to: abulla
thanks for the fast answer, it worked
but as another question, as in the pic i uploaded, the view of the flex duct looks narrow and better, when i choose Flex or Flex 2, the looking for the it is not "pretty"
can i chahne the look of the flex or flex 2 view ?
CoreyDaun
I don't believe that the appearance of the Flexible Duct Patterns is customizable.
chunky2k
in reply to: CoreyDaun
seems to be
as in the pic as it seems the guy used "rectangle" flex duct !!
CoreyDaun
Looking at the majority of the Flex Duct in the right image, it looks like the Flex Duct Pattern "Flex 2". Note that the appearance of this pattern is affected by the View's scale, so maybe that's making it look strange. The image below depict two differing scale Views of the same section of Flex Duct. Does this seem like the difference you're seeing?
muhammadadeel
Is it possible to have the same type of appearance show up in section view?
Rail Community
