Revit MEP Forum
Welcome to Autodeskā€™s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Flex duct disappears?
2 REPLIES 2
tfischer
538 Views, 2 Replies
I had a supply air system that was at 15'-0" or so AFF... I moved the duct system down to about 12'-0" AFF but when I did so I "lost" all of my flex duct. On my plan view, the flex duct is clearly shown in single line. However, when I go to my 3D view (or export to navisworks) the flex duct is NOT there.
What is odd is that when I moevd the system down, some of the flex duct did update and redraw, others did not. I even went back and deleted the flex on plan view and re-drew it... still with no luck!
Thoughts?
2 REPLIES 2
tfischer
in reply to: tfischer
anyone at all?
I tried going back in once again and re-drawing the flex without any luck.
This definately seems like a programming issue!
Chris.Aquino
To help the community get a better idea of what you are seeing, a small sample file, with screenshots would help give  a better picture of what you are seeing. If you can get the file down to a few ducts and terminals, you can post it on this thread.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
