What's wrong with the flex pipe with added insulation in a section view?
In a section view I see the correct picture without insulation.
But with added insulation the section view shows me the whole pipe (also the part, which is behind cross line).
Solved by Chris.Aquino. Go to Solution.
This is a known issue in Revit 2013 and previous versions.
While there is no fix for 2013, it does look like this issue will be addressed in the next version of Revit.
