Revit MEP Forum
Flange Family Parameter Formula
1 REPLY 1
diacreek
1063 Views, 1 Reply
A Invalid Input error message pop out when creating a flange family following Revit MEP 2010 Families Guide - Metric Tutorials.
Please help to figure out the reason.
1 REPLY 1
huangq
in reply to: diacreek
It seems that you entered "Lena2" as searched column,  the real column name in the CSV file is LenA2. Please try change the column name accordingly. By the way, I saw you enter 0' for default value, please also change it to 0 mm.
Please also make sure the file "M_Generic 1 Mpa Slip Flange.csv"  is copied to Lookup table folder. The look up table folder could be found in Revit.ini file, by the following clause:
LookupTableLocation=<lookup table file path>
On my computer, the clause is LookupTableLocation=C:\ProgramData\Autodesk\RME 2011\LookupTables, so my lookup table files are located in C:\ProgramData\Autodesk\RME 2011\LookupTables.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
黄庆九
Qingjiu Huang
Support Specialist
Product Support
