Revit MEP
Active Member
DrewH09
Message 1 of 2 (293 Views)
Fixture Units not calculating
293 Views, 1 Replies
09-27-2012 06:02 AM
I created a plumbing fixture family with a shared parameter (ie, HWFU).  When I set the connector to an Instance parameter, the fixture units calculate just fine.
I set the connector to a Type parameter, load the family into the project (overwrite existing & parameter values), change the Type parameter to a  number (1 in this case), the calculated fixture units in the pipe drop to 0.
Any ideas on why this isn't working?  I'm using Revit MEP 2013.
Active Member
DrewH09
Message 2 of 2 (290 Views)
Re: Fixture Units not calculating
09-27-2012 06:09 AM in reply to: DrewH09
I just noticed that whatever I set the "default" value to before I load it into the project is what's calculated.  Whenever I change the parameter, whether it be in the schedule or by Edit Type, it does not reflect in the pipe system.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
