Revit MEP
Active Contributor
Message 1 of 6 (226 Views)
Fire Alarm Symbol Plan vs. Ceiling
226 Views, 5 Replies
01-22-2014 05:15 AM
Why are my fire alarm sysmbols shown in plan view opposite in ceiling view (please see attached)?
Any suggestion/comments will be much appreciated.
CADastrophe
Message 2 of 6 (206 Views)
Re: Fire Alarm Symbol Plan vs. Ceiling
01-22-2014 07:51 AM in reply to: bvm76
Could you attach your Family file? Also, what version of Revit are you using?
Active Contributor
Message 3 of 6 (196 Views)
01-22-2014 09:21 AM in reply to: CADastrophe
Hi Corey,
Please see attached family as requested. I am using Revit Version 2013.
CADastrophe
Message 4 of 6 (190 Views)
01-22-2014 09:46 AM in reply to: bvm76
In your Family, disable "Maintain Annotation Orientation" - you can find this under Properties with nothing selected OR by going to Family Category and Parameters. This behavior is due to the Reflected Ceiling Plan viewing the object from the opposite direction with Revit trying to maintain the appropriate orientation.
Active Contributor
Message 5 of 6 (170 Views)
01-23-2014 12:12 AM in reply to: CADastrophe
Great!
What is the main purpose of this and when to use it?
CADastrophe
Message 6 of 6 (160 Views)
01-23-2014 07:38 AM in reply to: bvm76
It's a case-by-case setting - enable it if you need it. I can't immediately think of an example of when I would want to enable this option.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
