Revit MEP Forum
Filter creation based on elevation contraint
1 REPLY 1
338 Views, 1 Reply
Can anyone help me create a simple filter based on an electrical receptacles elevation? I'd like to apply this to a linked model so I can see what height above the floor receptacles shown in the architects model are at, so when I insert mine I don't have to click on each one to check the elevation. Thanks in advance!
1 REPLY 1
CoreyDaun
So far (as of Revit 2013), it is not possible to use the Elevation parameter in Filters or Schedules. You cannot even create a View Filter based on Level. But that's using the program as it stands. I may have heard mention of an Add-In that may be able to help. Search this forum and you'll likely find it.
Other than that, you're only other solution would be to create a Project Parameter and use that in your View Filter rules. Note that this parameter would have to be manually entered. Perhaps the best way to mass-apply such values is to create a Elevation View. There, you can select all of the elements at the same elevation and enter that value for all of them at once.
