I am attempting to make a generic residential air handling unit. I want to be able to select a heater size from a standard list of sizes and have it calculate the MCA automatically. I read something about loading a blank generic model into my family and using the family type parameter to get options in a drop down menu. I guess my question is "is this a good way to accomplish what I am trying to do" and if so how do I use the family type parameter in a boolean formula. If someone else has a better method I would like to hear that too. I did it with yes no para. for heater sizes and a beastly nested if statement initially but I have no way to prevent multiple heater sizes from being checked. Thanks in advance for any help/suggestions.
Solved by CoreyDaun. Go to Solution.
It should work to suit your needs. Refer to the link below for more info on this method. Don't hesitate to post if you encounter any difficulties!
