Revit MEP
norcaljess
Message 1 of 17 (660 Views)
Face Based Family won't host
660 Views, 16 Replies
02-01-2012 10:54 AM
My face based Air Terminals will not let me place them in the current project I'm working in.  When I try to place them, I get an error that says "Couldn't find an appropriate Host.  Try selecting a different Host Face or switch Placement Mode."  I have used them in 3 other projects with no problems.  Any idea why I can't get the ceiling to host them in this one?  Would it have something to do with the way I have the View Graphics set up for the architectural background?
Jess
Valued Mentor
julianjameson8403
Message 2 of 17 (648 Views)
Re: Face Based Family won't host
02-02-2012 03:06 AM in reply to: norcaljess
I presume you have ceilings visible in the view and that they sit within your view range and cut plane? Are you placing in floor plan or RCP? If floor plan - try using a ceiling plan to place them
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
norcaljess
Message 3 of 17 (642 Views)
02-02-2012 09:15 AM in reply to: julianjameson8403
I do have ceilings visible in VG.  Already checked that.  I am placing them in an RCP view, not floor plan.  However, I did try to do it in a floor plan when it wouldn't work in the RCP.  Didn't make a difference.  I've checked my view range & cut plane as well.  I am within the correct limits.
Jess
CADastrophe
Message 4 of 17 (632 Views)
02-02-2012 10:58 AM in reply to: norcaljess
Is it just that family that won't find a host? And in the View in which you are inserting the family, make sure that the host is visible (and isn't just a hatch pattern or something) - tab through the link elements and make sure you can see it.
norcaljess
Message 5 of 17 (627 Views)
02-02-2012 11:56 AM in reply to: CADastrophe
Just found a resolution for this problem.  Went into the Link's VG and turned off all categories under the Model Category tab EXCEPT ceilings.  This worked.  I then turned ONLY the lighting fixtures category back on so I could center my registers between them, and suddenly the ceiling won't host my registers again.  So it appears to be something with the light fixtures that the architect has in their model.  I can work with this.  I'll just place my registers, then move them after I turn the fixtures back on.
CADastrophe
Message 6 of 17 (622 Views)
02-02-2012 12:02 PM in reply to: norcaljess
The reason for this behavior is that the architect's lights are still cutting holes into their ceilings, and since there is a "hole" there, you cannot host anything to that particular spot. One of our early solutions to this was to create Generic Ceilings to host our elements.
norcaljess
Message 7 of 17 (616 Views)
02-02-2012 12:06 PM in reply to: CADastrophe
Even though it's not just that hole, but the entire ceiling that won't host my family?  And if that's the case, then why will it host my family when I turn the lights off?
CADastrophe
Message 8 of 17 (606 Views)
02-02-2012 12:27 PM in reply to: norcaljess
You're right, then. There's another issue going on there. If you end up finding out any more info, please post. I believe I have heard of this before, and I'd like to know the reasons...
norcaljess
Message 9 of 17 (603 Views)
02-02-2012 01:40 PM in reply to: CADastrophe
Will do.
New Member
justins
Message 10 of 17 (553 Views)
02-15-2012 11:20 AM in reply to: norcaljess
Thanks for figuring that out, we are having the same problem.  Even tried hosting in a 3D view and had no luck.  If you figure out why this is happening please post.  I'll be looking into it to and will post if I figure anything out.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
