Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
FABmep Import for Revit MEP available on Autodesk Labs
36 REPLIES 36
Message 1 of 37
scott.sheppard
4768 Views, 36 Replies
There is a new technology preview you can try:
http://labs.autodesk.com/utilities/revit_fabmep/
The FABmep Import for Revit MEP is a free technology preview that enables users to import Autodesk Fabrication FABmep models to provide round-tripping capabilities for as-built/record drawing purposes.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
36 REPLIES 36
Message 21 of 37
csheesley
in reply to: scott.sheppard
What do you mean by the extensions. Is this helping you get from FAB MEP to REVIT MEP? That is our current task.
Message 22 of 37
csheesley
in reply to: NelsonStark
Where did you get the dll files? We are having this same issue.
Message 23 of 37
scott.sheppard
in reply to: csheesley
Peter Jackson shared some information:
Revit MEP For Engineering 2013 Conversion to Fabrication FABmep 2013
Its Fab Autodesk Fabrication Blog
Extending Autodesk Revit models to Autodesk Fabrication
  • Please see attached taken from the Fabrication Blog. Below is the video link illustrating the process.
Autodesk Fabrication FABmep 2013: Export and Import to Autodesk Revit
Fabrication FABmep 2013 Conversion to Revit MEP For Engineering 2013
Do you need to import Fabrication FABmep models back into Revit MEP?
Taking Fabrication FABmep models back into Revit 2013
http://autodesk.typepad.com/fabrication/2012/08/taking-fabrication-fabmep-models-into-revit.html
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
Message 24 of 37
lhuynh
I wish you could map things other than dimensions. More specifically item numbers to item mark.
Message 25 of 37
scott.sheppard
in reply to: lhuynh
Thank you for the suggestion. THis is what we need to hear in the technology preview stage.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
Message 26 of 37
I have not yet received a new installer from the team although I believe their plan is to continue to collected feedback via an extended technology preview.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
Message 27 of 37
I posted a new build on the Autodesk Labs site this morning. This build extends the technology preview for Revit MEP 2013 users to March 31, 2014.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
Message 28 of 37
NelsonStark
I have removed old install and try to re-install the new one but just getteing a notice that “The Component has expired and cannot be loaded” what else do I need to do?
Message 29 of 37
bparrell
Same thing here.Just e-mail Darren before I posted about issue
Bob Parrell
Message 30 of 37
stephen.haycock
in reply to: bparrell
I've contacted the developer directly, he's sent me an email this morning saying that he had updated it and it seems to be working fine now.
Version 3.014.186.0
Message 31 of 37
Any ideas on how to import cable tray and fittings?
Message 32 of 37
I posted an update fo 2013 this morning and another installer to support Revit MEP 2014.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
Message 33 of 37
bparrell
in reply to: stephen.haycock
Everyone should be happy with the rotating elbows being fixed.
Message 34 of 37
Does anyone know if the flip and hand orientation toggles work, I'm trying to flip a 'Y' branch but nothings happening!
Message 35 of 37
Had a bit of a issue yesterday when mapping a copper fitting to a Revit copper fitting and using the calculation tool. When using a formula to halve the 15mm diameter it calculated it as 7 and not 7.5 which means there's a rounding issue somewhere. To test I edited the fitting and added another parameter to check the original number that was being passed over and it was indeed 15.
Has anyone else experienced this rounding issue?
Message 36 of 37
For those who wish to get started with this technology, there is a tutorial that includes a document, 3 videos, and some sample files.
http://labs-download.autodesk.com/us/labs/trials/worldwide/FabricationFABtoRME.zip
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
Message 37 of 37
Paul-CFL
Im a novice at this and am attemting to map a ventilation system. Im struggling with the mapping of the round bend to the Revit round bend as the bend always comes in at 300mm. So effectivelly 300mm is the default. Ive had a play with the different dimensions Map settings but nothing seems to change it from the 300mm default.
Any information would be greatly recieved.
Any mapped dimensions from FAbrication CADmep to Revit would be a massive help.
