Revit MEP
Member
Message 31 of 37 (411 Views)
Re: FABmep for Revit MEP available on Autodesk Labs
05-03-2013 01:46 AM in reply to: stephen.haycock
Any ideas on how to import cable tray and fittings?
Board Manager
Message 32 of 37 (377 Views)
05-15-2013 08:32 AM in reply to: stephen.haycock
I posted an update fo 2013 this morning and another installer to support Revit MEP 2014.
Scott Sheppard
Program Manager
Autodesk Labs
Message 33 of 37 (359 Views)
05-16-2013 09:50 AM in reply to: stephen.haycock
Everyone should be happy with the rotating elbows being fixed.
Member
Message 34 of 37 (341 Views)
Re: FABmep Import for Revit MEP available on Autodesk Labs
05-20-2013 07:13 AM in reply to: scott.sheppard
Does anyone know if the flip and hand orientation toggles work, I'm trying to flip a 'Y' branch but nothings happening!
Member
Message 35 of 37 (305 Views)
06-06-2013 01:23 AM in reply to: stephen.haycock
Had a bit of a issue yesterday when mapping a copper fitting to a Revit copper fitting and using the calculation tool. When using a formula to halve the 15mm diameter it calculated it as 7 and not 7.5 which means there's a rounding issue somewhere. To test I edited the fitting and added another parameter to check the original number that was being passed over and it was indeed 15.
Has anyone else experienced this rounding issue?
Board Manager
Message 36 of 37 (245 Views)
07-08-2013 07:56 AM in reply to: stephen.haycock
For those who wish to get started with this technology, there is a tutorial that includes a document, 3 videos, and some sample files.
http://labs-download.autodesk.com/us/labs/trials/worldwide/FabricationFABtoRME.zip
Scott Sheppard
Program Manager
Autodesk Labs
New Member
Message 37 of 37 (215 Views)
07-10-2013 04:02 AM in reply to: scott.sheppard
Im a novice at this and am attemting to map a ventilation system. Im struggling with the mapping of the round bend to the Revit round bend as the bend always comes in at 300mm. So effectivelly 300mm is the default. Ive had a play with the different dimensions Map settings but nothing seems to change it from the 300mm default.
Any information would be greatly recieved.
Any mapped dimensions from FAbrication CADmep to Revit would be a massive help.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
