Revit MEP
Member
msmadiso
Message 1 of 3 (365 Views)
Exporting generic annotations to .dwg in revit 2013 mep
365 Views, 2 Replies
09-26-2013 06:37 AM
I have a revit model (architectural model is linked as the background) where I have placed electrical and data devices on the walls, floors, ceilings, as required for this particular job.  The devices have a generic annotation symbol that shows up in plan view.  I'm attempting to export floor plans that show our electrical symbols to a dwg file for additional work and delivery to the client.  Because the symbols are generic annotations, revit by default exports the symbols as circles and lines, etc to the A-ANNO-NOTE layer.  How do I tell REVIT that I want the lines and circles to be exported as a block and that I want the receptacle block to be placed on an electrical layer and that the tel/data block should be placed on a data layer?
Mark
CADastrophe
Message 2 of 3 (319 Views)
Re: Exporting generic annotations to .dwg in revit 2013 mep
09-27-2013 05:54 AM in reply to: msmadiso
Unfortunately, Revit will always explode embedded Generic Annotations. You can tell Revit to at least assign them to a specified AutoCAD Layer by opening the Generic Annotation Family, creating a Subcategory, adding the lines to this Subcategory, and then in the DWG Export setup, expand the Generic Annotations category and designate a Layer on which to place these elements.
Member
msmadiso
Message 3 of 3 (280 Views)
09-30-2013 06:35 AM in reply to: CADastrophe
     At least getting things to the right layer will be a little help.
Mark
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
