Revit MEP Forum
Exporting Revit Views To CAD.
3 REPLIES 3
joel.banks
358 Views, 3 Replies
HI,
I'm trying to export a Revit view over to CAD (DWG) format, which I've done a million times! This time however after going thru the export process when I look at the CAD  drawing it seems to be missing some of the text and a lot of the piping that is in the Revit view. Any suggestions on how to fix this?
-Joel
3 REPLIES 3
CoreyDaun
in reply to: joel.banks
Have you tried changing the View to Wireframe prior to exporting? How about inserting the View onto a Sheet View and then exporting?
joel.banks
Yes I've tried both of those things. Sorry I should of clarified that.
CoreyDaun
I apologize, but the best I can do here is provide blind suggestions, such as have you tried modifying the Crop Region (if the elements are near the edge)? Do the missing model elements appear if exported from another View? Also, try doing a search in this forum - there's probably a few similar posts.
