Revit MEP
berniebooc
Message 1 of 3 (129 Views)
Exporting Pipe
129 Views, 2 Replies
03-18-2014 08:19 PM
Why is it after i exporting my piping design into dwg/dxf file that the properties of the pipe is a line o a hatch?  Is there any possible way that the pipe properties will remain after exporting it to dwg/dxf file? Please I need help on this. Thank you.
CADastrophe
Message 2 of 3 (100 Views)
Re: Exporting Pipe
03-19-2014 06:49 AM in reply to: berniebooc
The best you will be able to do is to export the Pipes as 3D Solids. The level of compatibility between these two very different programs will limit the exported information to the basic geometry. In order to do this, create a 3D View in Revit from which to export. Under the 'Modify DWG/DXF Export Setup' » 'Solids' tab, select "ACIS Solids".
berniebooc
Message 3 of 3 (84 Views)
Re: Exporting Pipe
03-19-2014 08:12 PM in reply to: CADastrophe
Thanks a lot..
