Revit MEP Forum
Export to DWFX with filter colors.
3 REPLIES 3
mrgoerlich
637 Views, 3 Replies
Is it possible to export to dwf or dwfx with the filter colors assigned in the view you wish to export. I am starting to use the app BimAnywhere and it would be helpful to see system colors on the field.
3 REPLIES 3
CoreyDaun
in reply to: mrgoerlich
Yep! Tested with Revit MEP 2013: Exported to DWFX and all of the colors are retained, including those bestowed by System Graphic Overrides and View Filters.
mrgoerlich
in reply to: CoreyDaun
Awesome is there a setting that controls that? Everytime i export to a dwfx and load it on my BimAnywhere app the colors go away but when i export from Navis the colors stay.
CoreyDaun
The setup can be found in the dialog on the 'DWF Properties' tab, ("Print Setup...") and it mimics the normal Print Setup dialog. Make sure that it's set to color.
I viewed the DWFX file using Autodesk Design Review 2013. Attached is my DWFX file which which shows three sections of colored Duct; try viewing it with your App.
