Revit MEP
Distinguished Contributor
mmermel
Message 1 of 5 (432 Views)
Export to DWF: set default to DWF not DWFx
432 Views, 4 Replies
07-13-2010 06:24 AM
Is there a way to set my default DWF format to DWF instead of DWFx?  My plotter does not currently recognize the DWFx as a valid format, probably because of some issue I have not had time to look into.
Mitch
jd
New Member
jd
Message 2 of 5 (294 Views)
Re: Export to DWF: set default to DWF not DWFx
11-07-2011 04:58 AM in reply to: mmermel
Did you find a solution? We have searches for a way to change the default as well.
Jens
Active Contributor
mradamdavis
Message 3 of 5 (236 Views)
01-04-2012 09:44 AM in reply to: jd
when asked to save your DWF/DWFx file, use the drop down to select what type you would like to use.  Hope it helps
mmermel
Message 4 of 5 (229 Views)
01-04-2012 10:37 AM in reply to: mmermel
Sorry, but that does not help.  I already know about that.  The problem is that no matter how much you educate people about the setting they must use, they forget about it.  That means that if I never want anyone to accidentally plot to a DWFx, I need a way to set DWF as a default.
M
CADastrophe
Message 5 of 5 (224 Views)
01-04-2012 11:09 AM in reply to: mmermel
We have that issue too, with Worksets and DWFs. My solution was to make each user wear a reminder WWJD bracelet. (We Want Just .DWFs!). But there may be converters out there that might be faster than re-plotting.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
