Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Export setup to a txt file
1 REPLY 1
jarrad27
1035 Views, 1 Reply
I have created an export to dwg setup in one project. I would like to be able to use that export setup in another project. I have searched the discussion groups, and apparently you can create a txt file of your export setup. I've tried, searched, and can't figure that one out. Any help is appreciated. Thank you in advance for any assistance.
Jarrad27
1 REPLY 1
CoreyDaun
in reply to: jarrad27
I don't see a way to export these options to a .txt file. You can use 'Transfer Project Standards' from the Manage tab to import the settings into another Project. Make sure you have both Projects open* and have the Project that you want to import the settings into the active Project . In the dialog following Transfer Project Standards, ensure that the "Copy From:" at the top displays the correct Project. Then, simple click "Check None" and then find "DWG/DXF Export Setup Settings" from the list and check the box.
*I transferred my export settings to a blank project and saved it. That way, I don't have to open another entire Project from which to copy it, just this specific blank one.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
