Revit MEP Forum
Export Revit sheets to CAD - Viewport Scale Issues
3 REPLIES 3
kharris
1131 Views, 3 Replies
Morning,
I have exported all my Revit sheets to CAD without any issues, but when I select the viewport in the created CAD files the scale of the viewport is incorrect.
Eg. Revit scale = 1:100, CAD scale = 0.0100000
Everything in the CAD file is the correct size, no problem with the content, just the viewport.
Thanks for any help!
Kyle
3 REPLIES 3
fernanda.firman
in reply to: kharris
Thank you for visiting our blog!
I could not reproduce the issue on my end. I would say that it a set up issue.
Have you check the units for both AutoCAD and Revit?
Keep in mind that in one foot there are 304.8mm .
Please post a sample rvt and dwg file with the setup you have and I can investigate.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
kharris
Thanks for the reply!
It seems the CAD file corrected itself. I'm not sure what happened but when I opened the CAD file a few days ago the viewport was now showing the correct scale.
Thanks for your help though,
Kyle
fernanda.firman
Glad is all working!
Revit Clinic
