Revit MEP
Valued Contributor
tkendrick
Message 1 of 3 (180 Views)
Accepted Solution
Exit Text Editor
180 Views, 2 Replies
11-13-2012 06:36 AM
Has anyone found the way to exit the text editor box with the keyboard. In AutoCAD you could hit CTRL+ENTER to exit the text editor box. I've tried that and ALT+ENTER, SHIFT+ENTER. I found a blog post that said CTRL+LeftARROW, but that just jumps the cursor to the left.
I hope there is a way. I like being able to finish text with the keyboard, seems easier to me, than having to click outside the text editor box to finish the text.
Use this link to tell Autodesk about features you need:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
*Expert Elite*
CADastrophe
Message 2 of 3 (147 Views)
Re: Exit Text Editor
11-14-2012 06:07 AM in reply to: tkendrick
I tried for quite a bit but have not been able to find a way to accomplish this. What, if I may ask, would be the benefit of ending the Text Editor with the keyboard? You'll likely need the mouse for the next command/action anyway, right?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Valued Contributor
tkendrick
Message 3 of 3 (138 Views)
11-14-2012 07:51 AM in reply to: CADastrophe
No benefit other than my own happiness.
That is how I would like it to work. I find it more convenient for me to be able to end text editing with the keyboard instead of moving to the mouse having to find that tiny cross-hair that you can't change the size of (added that to the wishlist) and make sure it's out of the text box to click to end editing. By being able to end text editing with a keystroke it then doesn't matter where the mouse ended up after typing.
I know this is miniscule in the grand scheme of things. I was just curious if it was possible. Like everything else you adapt yourself to fit the workflow.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
