Revit MEP Forum
Error when I do anthing
5 REPLIES 5
ssteenbeke
578 Views, 5 Replies
I get the Operation could not be completed eror jut about every 5-10 minutes when working in MEP13. The full error is "This operation could not be completed. Please try again. If the problem persists, save any changes to models from the Revit server locally and contact your administrator."
I can't seem to do anything with out getting that meassage. I can't save after I make an inital central file and it doesn't look like I make a central file at all because the save and sync are greyed out.
5 REPLIES 5
RandMan
in reply to: ssteenbeke
Did you export the errors and warning message?  It will list the conflict.  It may have something to do with the setup of your model.
ssteenbeke
in reply to: RandMan
It isn't that kind or error. It is a pop up window. This is the one I get
VWD-MLM
Are you Creating a "Local" File AFTER creating the Central?.....Sounds like you're still working in the Central file.
Mike
Michael L. Maloney
Virtual World Designs
VDC & BIM Model Design, Clash & Coordination
mike@VirtualWorldDesigns.com
BDSU 2015, 2016
Charlotte, NC ; Fort Mill, SC
ssteenbeke
in reply to: VWD-MLM
I get this after we have created the central and have made a new local copy. It doesn't seem to be project spacific either.
LinconBV
We have the same problem. Did anyone find a solution?Because it seems to be project specific.
