Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Equipment Families Spanning Mutiple Floors
2 REPLIES 2
SLDBrown
270 Views, 2 Replies
Hello All,
I am building large items of equipment for a three story development. Some items of equipment span from the basement to the third floor. Currently, if I'm working in a basement plan, I am seeing the top of the equipment all the way to the third floor. How can I get the equipment to mask itself beyond my cut plane settings?
Steve
2 REPLIES 2
CoreyDaun
in reply to: SLDBrown
Unfortunately, only certain Categories are "cuttable" (such as Generic Models) and the MEP Categories in general are not. The only way I can immediately think of is to model each "vertical section" as an nested Shared Family. Then, in the Project, each nested component's visibility will be determined on an individual basis. If you can elaborate on what you're dealing with here, perhaps a more definitive solution can be found?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
SLDBrown
in reply to: CoreyDaun
I can categorize my equipment as a generic model and doing so will serve my purpose. Your second suggestion was my plan B. Thanks for that excellent nugget of information.
