Hello All,
I am building large items of equipment for a three story development. Some items of equipment span from the basement to the third floor. Currently, if I'm working in a basement plan, I am seeing the top of the equipment all the way to the third floor. How can I get the equipment to mask itself beyond my cut plane settings?
Steve
Solved by CoreyDaun. Go to Solution.
Unfortunately, only certain Categories are "cuttable" (such as Generic Models) and the MEP Categories in general are not. The only way I can immediately think of is to model each "vertical section" as an nested Shared Family. Then, in the Project, each nested component's visibility will be determined on an individual basis. If you can elaborate on what you're dealing with here, perhaps a more definitive solution can be found?
