Revit MEP Forum
Elevation Difference
2 REPLIES 2
bvm76
527 Views, 2 Replies
What makes the elevation of a link Revit model different from the elevation of the host drawing? Please see attached.
Please mark Accept as Solution if your question is answered!
Thank You.
2 REPLIES 2
Rian32
in reply to: bvm76
It's probably you have your level set to survey point and the link model is set to project base point or vice versa.
I don't currently have a revit machine right now so instruction may be a little bit off.
1. Click on the level and open the properties dialog box.
2. On the property dialog box click "Edit Type".
3. Constraints-> Elevation Base -> Change Project Base Point to Survey Point or vice versa.
bvm76
in reply to: Rian32
Both are set to project base point.
I linked the revit file using center-center but when I change to origin-origin this solved the issue.
Thank You.
