Revit MEP
Valued Contributor
bvm76
Message 1 of 3 (184 Views)
Elevation Difference
184 Views, 2 Replies
10-03-2013 02:18 AM
What makes the elevation of a link Revit model different from the elevation of the host drawing? Please see attached.
New Member
jdiala
Message 2 of 3 (121 Views)
Re: Elevation Difference
10-03-2013 10:42 PM in reply to: bvm76
It's probably you have your level set to survey point and the link model is set to project base point or vice versa.
I don't currently have a revit machine right now so instruction may be a little bit off.
1. Click on the level and open the properties dialog box.
2. On the property dialog box click "Edit Type".
3. Constraints-> Elevation Base -> Change Project Base Point to Survey Point or vice versa.
Valued Contributor
bvm76
Message 3 of 3 (99 Views)
10-04-2013 12:38 PM in reply to: jdiala
Both are set to project base point.
I linked the revit file using center-center but when I change to origin-origin this solved the issue.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
