Revit MEP Forum
Electrical annotation transparency
3 REPLIES 3
auto99
413 Views, 3 Replies
You can see my disconnect switches creates a line gap on the HVAC equipment they attaches to.  Is there something I can change to make it transparent?
Or can I do wireframe selectively?  Just the HVAC on wireframe view?
3 REPLIES 3
CoreyDaun
in reply to: auto99
The source of this behavior is under Mechanical Settings » Hidden Line. You can either disable "Draw MEP Hidden Lines" or set the gap sizes to 0.
The above is a Project-wide effect, though. You can eliminate this per View by setting the Visual Style to Wireframe, but you cannot assign a Visual Style to a specific Category. You could also change the View's Discipline to Coordination to prevent Revit from creating these gaps.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
auto99
in reply to: CoreyDaun
Thank you.  I guess I have to live with this limitation.
abulla
in reply to: auto99
In this particular view, you could turn your Mechanical Equipment to transparent, that may clear up some of the issues.
