I also have found there is not a Feed-Thru option. I did connect the panel directly to the transformer in order to propagate the calculations up to my distribution panel. So the only thing you loose by doing that is showing the connected load of the sub-panel to the feed-thru panel. Feed-thru connection option needs to go into the wishlist.
