Revit MEP Forum
Electrical Distribution systems
5 REPLIES 5
p.addington
1089 Views, 5 Replies
Hello again.
I seem to be having a little bit of trouble with the electrical system settings in MEP. I've managed to create a three phase distribution system and it works (400 / 230 three phase - South African Standard) but I seem to be having a problem with a single phase distribution system (230 Single phase - South African Standard)
I've created a three phase distribution panel that sees the three phase system, but when I modify it to a single phase distribution panel it cannot find the single phase distribution system.
Can it be that I have to create a single phase panel from scratch? or is the problem else where?
Patrick.
Design Technician
CKR Consulting Engineers
Nala Consulting
Sandton
South Africa
5 REPLIES 5
in reply to: p.addington
I assume you tryed the mep settings
p.addington
Yes i did try the distribution systems, i have set up two more in the voltage definitions as well as the distribution systems. It only picks up my three phase system and not the single phase system. I think it may be a problem in my DB family settings.
Design Technician
Nala Consulting
Sandton
South Africa
Its like a big secret with how things work.  there should be more intuitiveness.
rene.sommer
To assign a distribution system to a panel, the connector has to match the number of poles and the voltage.
In your case, you should edit the panel family, select the connector, change the number of poles to 1 and check that the voltage matches 230 V. After reloading the family in the project, you should be able to select the single phase distribution system.
Rene Sommer
p.addington
in reply to: rene.sommer
You're a genius, thank you so much Rene. It works now...
Design Technician
Nala Consulting
Sandton
South Africa
