Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Easiest way to change families from imperial to metric
2 REPLIES 2
543 Views, 2 Replies
I have some families that I couldn't find the metric version of them and they are all imperial
what's the quickest way to make them metric?
I don't want to go to project units and change every single unit one by one in the family file and then load it to project
Cheers,
M
2 REPLIES 2
CoreyDaun
I've done some searching and I have not been successful in finding anything. For the most part, it shouldn't matter too much because the Family will be loaded correctly into a Metric Project anyway, regardless of the Family's Units settings because Revit uses its own internal values for length. If you still need to find a way to convert the Units en masse, then I suggest asking if this is possible on the Revit API board.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
in reply to: CoreyDaun
Thanks mate,
will do..
It is a real pain when I want to change the parameters value in my Revit model when they are all imperial and all my calculations are metric.
Cheers,
Mehdi
