Revit MEP
cesslinger
Message 1 of 19 (229 Views)
Duplicating views
229 Views, 18 Replies
04-16-2014 08:16 AM
I would like to show my mechanical equipment power on a separate power plan. My problem is I do not know how to show the electrical equipment/devices on the mechanical power plan without them showing on main power plan and vice versa.
Active Member
Desaltivo
Message 2 of 19 (220 Views)
Re: Duplicating views
04-16-2014 08:51 AM in reply to: cesslinger
I'm not sure I understood your question correctly, but if you're using a callout view for the power plan, you should be able to change the "Disciplne" field to show Mechanical, Eletrical etc.
cesslinger
Message 3 of 19 (211 Views)
04-16-2014 09:35 AM in reply to: Desaltivo
I am duplicating the power plan to create a mechanical power plan. Not using callouts.
Active Member
Desaltivo
Message 4 of 19 (206 Views)
04-16-2014 09:49 AM in reply to: cesslinger
Uhm, so you shouldn't be having any problem changing the Discipline. Have you tried that method? (It's under the Properties of the View). Unless you made a Dependent View, you should be able to change it. If you can't, you should check if the view has a Template applyed, change it to <none> then you'll be able to change the Discipline.
cesslinger
Message 5 of 19 (201 Views)
04-16-2014 09:53 AM in reply to: Desaltivo
I have the discipline set at Electrical. What I am trying to do is duplicate the power plan to create a mechanical power plan. The issue I am having is that the electrical devices on my power plan are showing up on the new plan I created. When I delete the devices on the new mechanical power plan, it deletes the devices on the base power plan.
apjones
Message 6 of 19 (198 Views)
04-16-2014 10:19 AM in reply to: cesslinger
You will likely have to use filters.  Look into setting up filters and apply them to the view to accomplish this.
Pete
AutoCAD 2014 Certified Professional
CADastrophe
Message 7 of 19 (194 Views)
04-16-2014 11:08 AM in reply to: cesslinger
There are multiple ways to accomplish this, and two of them are:
1. Place the Mechanical Power and the Main Power elements on separate Worksets and under V/G for each View, turn off the unwanted Workset.
2. Create two View Filters for the appropriate Category(ies) and set the Filter Rules for one to "Comments" "equals" "Mech" and the other to "Comments" "does not equal" "Mech". Add the appropriate View Filter to your Views and disable the Visibility checkbox. Now, to designate an element for the Mechanical Power Plan, select it and enter "M" in "Comments" under Properties.
cesslinger
Message 8 of 19 (155 Views)
04-17-2014 12:36 PM in reply to: cesslinger
Thanks! The filter option worked great!
cesslinger
Message 9 of 19 (137 Views)
04-18-2014 06:00 AM in reply to: CADastrophe
I was able to create my filters for the mechanical power. Now how do I get keynotes to show only for that page. My keynotes are showing up on both plans, as well as text.
Thank you
CADastrophe
Message 10 of 19 (131 Views)
04-18-2014 06:48 AM in reply to: cesslinger
Did you duplicate the Plan as a Dependent? If so, the Dependent View will share the exact same V/G Settings and Annotations as the "Master View", and any changes made to either View will identically affect the other.
Did you duplicate the Plan with Detailing? If so, the annotations from the original View were copied over. They can safely be deleted without affecting the original View.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
