I am routing ductwork under a concrete slab. I need to make the linework represent itself as hidden. The slab is a linked Architectural Item. My discipline is set to Mechanical. The segment of duct I need to show as hidden is circled in blue.
Is this possible? See attached....
Solved by aksaks. Go to Solution.
Solved by Jrobker. Go to Solution.
1. Make sure your view range Bottom is 0 and your view depth looks down below the floor.
2. In Manage-->Additional setting-->Linestyles, change <Beyond> to a dashed linestyle.
This is a global effect. Any element that is below the Bottom view range will show as the linestyle you have assigned to <Beyond>.
Hey guys, I ran into almost the same problem. I followed the directions and It works perfectly for rfa's but when i tried the exact same thing for fabrication parts (ITM's) I wasn't able to achieve the same outcome. The blue in the picture is the rfa and the black are the ITM's. Any help would be greatly appreciated. the 2 horizontal are the exact elevation and the left vertical are below.
Did you read the two posts marked as solutions? They solved the issue for the OP.
If those don't work for you, you might have something else going on and should start a new thread.
I have my settings set up the same as "Jrobker" outlined them. The solution that "aksaks" provided, while a good solution and one we have used in AutoCAD before, is to labor intensive for what I am trying to achieve. I am having the same exact issue with MEP Fabrication Ductwork as "jes.gonzalez" shows and was hoping someone had a solution for that.
The <Beyond> line style works perfectly with RFA's and Revit items but doesn't have any effect on MEP Fabrication Ductwork.
The OP didn't mention fabrication. You should probably start a new thread with the additional information.
