Revit MEP
lotta.johannesson
Message 1 of 3 (174 Views)
Ducts in coarse mode - doesn't get correct appearance
174 Views, 2 Replies
11-15-2012 04:37 AM
Hello!
I have a duct model, need to print it in a coarse mode. The duct system has both tap and tee in it, the tee looks fine but the tap gets a different look.
It is not the tap fitting that is the problem, it is the duct it self. I get the same behavior in any model I try, on any tap I try.
I've attached a jpg for you to look at. On the right picture you can see that it is the duct that is misbehaving...
Any tips?
Thanks!
//Lotta
Fell in love with Revit in 2008.
Don't forget: Kudos and Solutions!
Valued Mentor
julianjameson8403
Message 2 of 3 (168 Views)
Re: Ducts in coarse mode - doesn't get correct appearance
11-15-2012 05:14 AM in reply to: lotta.johannesson
Edit the linework in the tap family so it look like the tee - if that is how you want it to present. You should just have to delete a couple of lines and constrain a symbolic line to the main ref plane.
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
lotta.johannesson
Message 3 of 3 (147 Views)
11-16-2012 03:45 AM in reply to: julianjameson8403
Hi JulianJameson8403
If it was the tap that created the problem, your solution would be great. Unfortunately it is the system family duct itself that is creating this. I've already edit the tap with the visibility settings. If I pick the tap it only shows as a single line in coarse mode.
If you would be kind to look at my attached picture I hope you can see that in the right picture I hover over the duct and all of it lightens up. It also shows on the tooltip.
Thanks for your participation!
//Lotta Johannesson, Sweden
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
