Revit MEP Forum
Ducts/Pipes will NOT display in 3D Render
4 REPLIES 4
MikeBartell
2227 Views, 4 Replies
I can not get pipes or ducts to display in a 3D rendering. Other mechanical elements will display such as diffusers, radiant ceiling panels, and VAV boxes.
I have tried to apply material types to duct/pipe sytems but the elements will still not show up in a generated Rendering
this is incredibly frustating.
I am using Revit MEP 2012
4 REPLIES 4
CoreyDaun
in reply to: MikeBartell
I tested in a blank project with ducts made of Marble and pipes made of Grass (image attached).
As a test, copy some the offending Pipes and/or Ducts to a new project and attempt to render them. Also, could you attach a full-screen (to include application buttons at the bottom) of the 3D View you're rendering?
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Randy_CaS
Could it be your view detail level is set to coarse and you are only viewing single lines for ducts? Just a thought
Martintj
in reply to: Randy_CaS
I use 3d views quite a bit and did you check the linked model detail level and override if necessary? just had this same issue and that solved it for me.
rpinella
Try to change the Sun Setting configuration.
