Is it possible to add another arrow to the duct_size_tag ? That is, two ducts of the same size with a single tag, two arrows.
Thank you very much.
Luc
Yes and no.
Yes, meaning you can fake it by adding either a "dummy" piece of text and leadering from that or a generic annotation that has nothing in it (something with an on/off visibility) and leader from that.
No, meaning you cannot from the single duct tag.
What version are you using and I'll send you a "fake" leader?
You have to assign both the arrow and dot to the type once inserted into your project.
The dot that is visible when placed can be turned off. It is there so you can see the family and move it around.
Remember, if the tag moves, these arrows aren't going with it. It's a crappy solution but the only solution to multiple arrows.
Your welcome. If I can do anything to prevent people from going through what I had to when learning this program I will help. I wouldn't wish Revit upon my worst enemy.
