Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Duct pressure loss report??
10 REPLIES 10
Message 1 of 11
vkyilmaz
607 Views, 10 Replies
In duct pressure loss report fitting losses either read -99999 or 0. i failed to find a sloution. do anyone have an idea?
thnks/rgrads.
10 REPLIES 10
Message 2 of 11
Mehdi.Kardehi
in reply to: vkyilmaz
are all your ducts connected and do they all have air flowing in them?
you can go to system browser (press F9) to find out
Message 3 of 11
vkyilmaz
in reply to: Mehdi.Kardehi
They are all connected and when I check through system inspection there are flow through all sytem.
Bu e-posta, Turkcell BlackBerry ile gönderilmiştir.
Message 4 of 11
Mehdi.Kardehi
everything is fine on my side
Do you want to upload here to have a look?
If too big you can email it to info@gbeservices.com.au for me to look at
Message 5 of 11
vkyilmaz
pls. find attached one floor of the system. hope you can tell me the problemç
thkns&rgrads,
Message 6 of 11
Mehdi.Kardehi
mate..can't say much from the photo...would need the .rvt file
Message 7 of 11
yucelonur1
Actually same problem for my side,
For example;
 - Round transformation; you can see properties tab; Loss method, loss method settings.
   If you select coefficent from ASHRAE then revit will automatically select data ( from ashrae table )
This point, we have a big problem !
There are a lot of fittings that we may use our projects. For example, different Tee's, rect to round transformer, shoe branch, reducers, wye etc.
Problem 1 - If you want to create a new family, how can i input loss coefficeint data !!!
Problem 2 - If you use revit default fittings for tee. Revit did not give a permission change loss method setings. Report show 0 for tee. Of course, i want to input data for manually however i could not find yet.
Help me please !!!
Message 8 of 11
cvc42100
in reply to: yucelonur1
I have the same problem  ! I use metric and french soft !
Arnaud H : Projeteur CVC/S - ACP (Autodesk Certified Professional ) Revit MEP
Message 9 of 11
gmayEngineer
in reply to: cvc42100
Hi, try to change the decimal separator of your computer from "," to "."
Go to the settings of your computer into "region" and change it.
Reboot revit and launch the calculations again, it should work
GM
Message 10 of 11
alejandromata.io
It would be great if Revit could the decimals configuration (".", ",") from our Revit Project units Smiley Happy
Message 11 of 11
cvc42100
in reply to: alejandromata.io
Well, it works now ! thanks everyone and good WE 🙂
Rail Community
