Revit MEP
Distinguished Contributor
Message 1 of 4 (232 Views)
Accepted Solution
Duct - level associations
232 Views, 3 Replies
10-11-2012 08:31 AM
Small but expensive problem:  Every time we draw a duct, it associates to a particular level, which we don’t want to use and that we have to spend time changing.
Is there a default setting somewhere in the bowels?  Thanks
Active Contributor
Message 2 of 4 (217 Views)
Re: Duct - level associations
10-11-2012 08:50 PM in reply to: plawton5092
The duct will normally refernce from the associated level for the view.  If you select duct and change the refernce level it will maintain the reference level until you revert back.  The other option would be to create a view associated to the required level and model through this view.
Active Member
Message 3 of 4 (205 Views)
10-12-2012 08:22 AM in reply to: plawton5092
Go to insert a new duct, but before actually placing the duct on the plan, change the Reference Level in the properties box.
Message 4 of 4 (194 Views)
10-12-2012 09:53 AM in reply to: plawton5092
Thanks tim.winnington for "The other option would be to create a view associated to the required level and model through this view."
Yes, the nuclear solution is the only one available, apparently.
I can understand why autodesk would not be able to provide the users with another check box to alter this setting .... after all, there are no check boxes left on the planet, because autodesk has used them all up for revit visibility controls.
Thanks again.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
