Revit MEP Forum
Duct cross section dimension
13 REPLIES 13
Message 1 of 14
harinarayana55
2782 Views, 13 Replies
Hi is there any way to give dimension to the bottom of the duct in cross section.
Present we are draw a line at the bottom of the duct and dimension given to the line.
Thanks in advance.
13 REPLIES 13
Message 2 of 14
chunky2k
in reply to: harinarayana55
do you mean you want to make the duct on certain height from the floor that you request on the section ?
if so, you make the section, make the Dim. for it
then click on the duct, after than you will see the Dim. value became smaller size, click on it, specify the lenght
hope i didn't get you wrong
regards
Variable Integrated Package L.L.C
Abu Dhabi - United Arab Emirates
Message 3 of 14
harinarayana55
in reply to: chunky2k
Hi chunkey
thanks for the reply.
I attach a revit model in 2013.I need bottom of duct in section without drawing a line.
Message 4 of 14
chunky2k
honestly
i dont think so, in this case you have to do it normally one by one
Message 5 of 14
harinarayana55
Hi
Sorry, if I am wrong. My doubt is not about prefix or suffix.
What I mean is how can I draw dimension to the bottom of the duct.
Default dimension can take only to the center of the duct.
I am unable to take dimension to the bottom of the duct.
Thanks in advance
Message 6 of 14
abulla
Press Tab when you're hovering over the ductwork in the Dimension command to select the bottom edge.
Message 7 of 14
harinarayana55
in reply to: abulla
 Hi Abulla
I don't know what I am wrong.
I am not able to select bottom edge even with tab.
Message 8 of 14
abulla
Hmm I'm not sure what the problem is then. Are you using an Aligned Dimension or a Linear Dimension? I was able to tag the top and bottom with an aligned dimension, I had to press tab to select the center of the ductwork.
Message 9 of 14
CoreyDaun
In the initial Section View in the sample project you attached, the Rise/Drop symbol is preventing you from selecting the top or bottom of the Duct. Open Visibility/Graphics Overrides and temporarily turn off the "Drop" and "Rise" Subcategories under Ducts.
Message 10 of 14
RickGraham
in reply to: abulla
Correct me if I'm wrong, but the Tab-select will not work for edges of ROUND duct?
Rick
Message 11 of 14
abulla
in reply to: RickGraham
Tab select will select the edge of round duct as well.
Message 12 of 14
RickGraham
in reply to: abulla
I stand corrected. I can now go home because I learned something new. 🙂 Thanks for the tip!
Rick
Message 13 of 14
harinarayana55
in reply to: CoreyDaun
Hi cadstrophe
thanks for the solutions. We are wasting our time with drawing a line for every bottom of the duct from long time.
thanks for all.
Message 14 of 14
harinarayana55
in reply to: abulla
thank u .
i think i am not explain the problem correct.
now i got the solution.
