Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Duct connector issue in family creation
3 REPLIES 3
Mehdi.Kardehi
366 Views, 3 Replies
Hi All,
I have made numerous fancoil unit families so far but this is the same time below is happening to me. Can someone help please?
When I select the face and add the supply air connector Revit put is offset from where I want although all the dimensions are set the same. I also figured out that I am not able to move it to it's right position!
3 REPLIES 3
bvm76
in reply to: Mehdi.Kardehi
could you upload the family for us to look at?
Please mark Accept as Solution if your question is answered!
Thank You.
Mehdi.Kardehi
in reply to: bvm76
See attached
Found the issue guys...
instead of using rectangle to make my supply connector I have used lines for this one...
It might have been something wrong with defining the constraints for the lines but as soon as I replaced it with a rectangle the issue is fixed!
