Revit MEP Forum
Duct Pipe accessories to have different color system type
2 REPLIES 2
mariusvanwyk2216
965 Views, 2 Replies
I don't have any systems created only using the system type to show supply air with a fill color blue and solid pattern. When I place a damper it changes to the color blue. I want it to display gray solid fill pattern.
The filter for the mechanical supply is set to = system type equals supply air.
I have tried applying a filter to duct accessories set to solid fill pattern gray = system type equals supply air and even tried other options and it does not change to gray.
Any suggestions please????
The reason I have not created systems with names are that this is a plant room and do not have any floors set up yet, it is about setting out the plant room to get the space required approved.
Regards
Marius
2 REPLIES 2
Revit applies filters based on the order in the list.
Try changing the order so that the accessories filter is applied last.
If that doesn't work, check the filter on a new view that doesnt have the system filter added, to make sure its working.
Thanks for the reply.
This is what happens when you work with someone else's creation. They have other check boxes checked that I don't. Revit and its check boxes.
My filter for mechanical supply had the duct accessories check box unchecked. The one I was working on had it checked. That is why the filter for the duct accessories did not apply.
Thanks.
Marius
REVIT AND CHECK BOXES - CHECK THE BOXES
