Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Duct Elevations
1 REPLY 1
597 Views, 1 Reply
Duct Elevations
Does anyone have problems with duct offsets (elevations)? Our office uses the x dimension to be the bottom of the duct. Everytime I reopen Revit I have to reset the justification setting for the vertical to be set to the bottom since the default is the middle. When I draw a duct at 10'-6" and the duct is a 24x12, it draws it correctly, but when I click on the duct in plan view, it will then say that the offset is 11'-0". It is taking my 10'-6" elevation and adding 6" from the 12" to make it the center of duct again. Is there a way to set the justification permanately and to have the duct read the correct elevation? Any suggestions would be appreciated.
1 REPLY 1
hjlcanton
yes and this issue has been repeatedly reported since so many years ago but Autodesk has just kept ignoring it...
