Does anyone have problems with duct offsets (elevations)? Our office uses the x dimension to be the bottom of the duct. Everytime I reopen Revit I have to reset the justification setting for the vertical to be set to the bottom since the default is the middle. When I draw a duct at 10'-6" and the duct is a 24x12, it draws it correctly, but when I click on the duct in plan view, it will then say that the offset is 11'-0". It is taking my 10'-6" elevation and adding 6" from the 12" to make it the center of duct again. Is there a way to set the justification permanately and to have the duct read the correct elevation? Any suggestions would be appreciated.
